Topic: Chrome door handles (Read 2874 times) previous topic - next topic
Chrome door handles
Try the junkyards also, You might find a nice set.
I didn't know the were so uncommon, I see more chrome than black up here.
Chrome door handles
Get chrome door handles off 50resto.com and then donate your old ones if they work fine to someone with a mustang missing a door handle or at least thats what i did.
Chrome door handles
Quote from: EricCoolCats;234675
Aw come on, Carm...with that year-round snow that y'all have in Canada, all you need is a hammer and a punch, and them frozen rivets will pop right out. ;)
Little tip: if you don't want to use pop rivets upon reinstallation, you can use 1-1/4" carriage bolts with some Loc-Tite. They're a little more secure as they're harder to drill out, won't let the handle flop around over time, and can be completely removable (with some elbow grease) when you want them to be. Plus they look cooler.
I used stainless steel 1/4" cap screws with nylock nuts when I reinstalled mine. I had considered using rivets again but remembered how much it sucked drilling the old ones out (rivets are not easy to drill when you can't pop the center out - it's the hardest part of the rivet so the drill bit wants to "walk" off of it).
Chrome door handles
The only problem with the py ones from the parts stores is they are made with plastic parts and they only last a few months till they break. I will be ordering these because they are made with all metal construction, the price is right and I have seen these up close and they look pretty good, better then the ones at NAPA http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEWAX%3AIT&viewitem=&item=140226674824
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Chrome door handles
I couldn't get the chrome handles off of mine fast enough...course, I'm going for the stealth bomber look, too :D
One of these fine days (ha, with the hurricane-influenced weather..? riiiighhhht) i'll have to get some pics of my bird...;)
Chrome door handles
I used aircraft hardware to reistall my handles. Nothing says I love you than titanium.
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
Chrome door handles
Ford still sells the handles, I picked up a repop first and what a piece of junk, So I called the dealer and they had them, cost about $55.00 but well worth the price, a nice tight handle with no slop or rubbing the body when you pull up. I believe rangers have the same handles.
Chrome door handles
I just bought the foxbodyrestore handles and they are tight also and they have a bigger spring and look pretty  good, and for under $30 bucks how can you go wrong will post pictures later
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
