Topic: '85 XR7 - 7300 (yes, HUNDRED) Miles (Read 2504 times) previous topic - next topic
yeah, with the vents at the rear of it.
Probably a good thing. The shield only serves to hold moisture. I've had to replace the tank in my 88 Cougar and 88 T-Bird because the bottom rusted out due to dirt gathering in that shield and holding water. When I had the T-Bird in the shop doing the tank the other guys in the shop couldn't believe that a car with so little rust could have such a rusty tank...
Most have body color strut towers, firewall etc... The Red '88 Sport my racing buddy owns, has what appears to be reddish brown primer under the hood, nowhere near the exterior color...
Nice car but yeah, it must have spent some time sitting outside.  Did anyone notice the yellow showing through on the rear bumper?  Either that speedo has been swapped or changed or it spent a fair amount of time outside.  Still a nice car but not what I'm used to seeing in cars with less than 10K miles.
If the speedo was swapped,, someone cracked the code and got rid of the (S) indicator.
Maybe thats where bondocougar went to:D
Quote from: jcassity;235306
I didn't know that showed up on the buttstuffog ones.  If so, then a speedo swap would be less likely.
By the way, I wonder if there was shill bidding by the owner's friend.  g***b entered $6395 on Sept 3.  That is a losing max bid.
the whole thing seems a little odd. There is a lot of wear for 7300 miles. Why were the Marchals removed in the first place? The trunk lid insulation looks great but the hood insulation has alot of wear. The seams of the seats, joints of the dash and carpet look much dirtier than I'd like.
I was wanting to bid on this but just not comfortable doing so.
anyone notice the underside of the front bumper cover,, compared to the fog lamps in the trunk?
I also do not think there should be that much gas pedal carpet wear either.,, just an observation.  I no longer have my carfax account active but it would be nice to check in on that vin.
would anyone agree the slave cyl has a leak based on the stain pattern on the carpet drivers side?
Quote from: jcassity;235794
Scott,
5-speed cars in 1985 didn't have a clutch slave cylinder, that came about in '87.
Judging by the amount of uncleaned dirt under the front valance and the accumulation of dust on the kick panel near the hood release & embedded dirt on the clutch pedal and carpet pad, I'll bet that the current owner lives on a dirt road.
Removing my CSI hat now.  ;)
Other than a few spots on the driver side (that I think would come out) the carpet looks very clean and new looking.
All of the darker "blotches" in the carpet are more of the way the carpet reacts to the light depending on how the fibers are "standing".
I have that same carpet in my car and I have been trying to find a new replacement for several years now without success.
It's an unusual color that has a "sheen" to it when the light hits it and when in shadow it is noticably darker.
All of the aftermarket samples I have gotten from various companies have come very close to the shade of color as the original but they don't seem to have the "sheen"  and "shadowing effect" that the OE does.
Brent
:cougarsmily:
One of 1,246 built
looks good were can I get on of the stock shifter s.
Quote from: 88TurboCoupeman01;235886
They show up on eBay from time to time, but be prepared to spend some serious money for a nice one.
About the closest to the original is Ford part # XR3Z-7213-BA which is designed for the 1999-2004 Mustang. It's very similar in size and shape but lacks the "TURBO" embossing.
Brent
:cougarsmily:
One of 1,246 built
