Topic: SN-95 5-lug swap, 4whl disc Q's... (Read 6491 times) previous topic - next topic
Quote from: 88TurboCoupeman01;234199
I read the NATO introustions on how to do it and yes u do need the axles I thought u didn't sorry. Here is a basic way to do it, u can use mustang parts up front too.
http://natomessageboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=018500
No, Lincoln Mark VII parts up front. And that setup depends on what wheels you want to run holmes. Unless you have a hammer and a grinder in your toolbox. And just an FYI, that link only applies to 87-88TCs. ;)
Quote from: BCA;235089
hen without moving the a-arm, I mounted the ’94 spindle, hub & rotor on it and repeated the same steps and it was 2 mm narrower than the ’88 set-up. If you add to that the thickness of the rotor (the last one I measured was 6mm), it would be about 4 mm.
Then my math was teh suck (or more likely my measuring). Thanks for settling that.
Quote from: JeremyB;235130
I tried to be as close as I could and put the bubble at the exact same spot both times. I was going to use my 6-1/2 foot level which I believe would be more accurate but the ceiling was in the way. So I'm not going to say that this 4mm measurement is dead on 100% correct but it sure does bring some light to the subject. ;)
Brent
:cougarsmily:
One of 1,246 built
