Topic: Engine Harness (Read 2320 times) previous topic - next topic
Engine Harness
I see if the JY in my area has one. What years can I look for or do I have only get it from a 88 5.0 or Cat or can I get it from a 87 do have ABS or does that matter.
Engine Harness
I see if the JY in my area has one. What years can I look for or do I have only get it from a 88 5.0tbird or Cat or can I get it from a 87 do have ABS or does that matter.
Engine Harness
Quote from: 88TurboCoupeman01;235676
He needs one from an '88 5.0 ONLY...ABS was only on the TC's ;)
'87 harness won't work without some mods, easier to use an '88 harness, as I did.
Cats and Birds either/or will be fine, long as it's 5.0 and an '88. :D
I knew a guy that modded a 3.8 harness, but can't verify what he did, or even if it was feasible, as he had a lot of issues, but it DID run....sorta... :punchballs:
Engine Harness
I'm goin back to the yard soon,will look again.
Not sure but would a mk7 work?,I know there's at least 1 there.
Engine Harness
no. i need a 1988 thunderbird 5.0 harness. If there is a 1988 cougar 5.0 i might be interested. Thanks Guys
Engine Harness
Theres no such thing as a 88 ho harness.they were all so.
Thats why I mentioned a mk7 they were Ho.All the sensors are just about the same if not the same.
Engine Harness
Going to look today again.They got some new cars in.
Engine Harness
Nothing again.
Engine Harness
bump. I still need the Harness out of a 1988 thunderbird or cougar with a 5.0l
Engine Harness
I hope to be going back to the yard on Wednesday,weather permitting.
Engine Harness
I've got an EEC harness out of an 88 T Bird.
William
Engine Harness
heres a complete harnaee on ebay,It is an 87 though.
http://cgi.ebay.com/ebaymotors/Mass-Air-conversion-ford-mustang-with-map-sensor-87-88_W0QQitemZ150307801365QQihZ005QQcategoryZ33733QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Engine Harness
The description for that harness says it's for a Mustang.  Purportedly, Mustang harnesses won't work in our cars without extensive modifications.
William
Engine Harness
Quote from: 88 Blackbird 5.0;241431
I ended up finding one, but do you have the altenator harness for the 88?
Engine Harness
It's my understanding that most guys just splice into where the alt wires come out of the headlight harness.  Since the alternators on TC's were on the opposite side of the engine bay than what Sports did, I think a lot of guys splice in and extend the harness.
William
