Topic: VIN Decoding (Read 1254 times) previous topic - next topic
VIN Decoding
How can one determine whether a thunderbird r cougar is an 1987 vs a 1988? There has to be something in the vin number to tell you right? I have two 1987's, one v8 car and one turbo coupe, and 1 v6 1988. I can't seem to tell what signifies hte year? Anyone know?
I ask because I'll be going to a boneyard later on today and I've been told a 1988 v8 harness will plug right into the v6 harness. But in the yards they don't typically know between the two years.
VIN Decoding
Quote from: jpc647;233688
Look at the eighth digit in the VIN. It'll unravel the year:
Years 1980 through 2000 are designated by a letter from A to Y.
The letters I, O, Q, U, and Z are not used because they can be easily confused with a number or another letter.  A – 1980
  B – 1981
  C – 1982
  D – 1983
  E – 1984
  F – 1985
  G – 1986
  H – 1987
  I – not used
  J – 1988
  K – 1989
  L – 1990
  M – 1991
  N – 1992
  O – not used
  P – 1993
  Q – not used
  R – 1994
  S – 1995
  T – 1996
  U – not used
  V – 1997
  W – 1998
  X – 1999
  Y – 2000
  Z – not used
  Beginning with 2001, numbers are used to designate the model year.
  1 – 2001....
and so forth..
About the harness, yes, on '88 ONLY...will the 3.8 harness plug into the 5.0 harness, and vice-versa..2.3 will NOT interchange without serious mods. Good luck
VIN Decoding
V6 is easy - 1987 had CFI while 1988 had true fuel injection. But as for the VIN the 10th digit tells you. H=1987, J=1988
*EDIT* Well, I guess Beau wins...
VIN Decoding
Tenth digit, H=87  J=88
VIN Decoding
Thanks Guys,
  I'm searching for the v8 engine harness and have been told hte 88 is what i need. The 5.0 was essentially the same form 86-88. And i oculdn't tell and 1987 5.0 from an 88.
Thanks again.
