Topic: 2.3 turbo questions NEED HELP 2.3 GURU'S!!! (Read 2227 times) previous topic - next topic
no the fitting is off a turbo from a manual car
and ive never driven my mark on the road so idk how that power is.
Im comparing to how it was before. Put a non cracked EGR on it and it still leaks out the back so it needs some more work but it helped some what of the problems.
Now it will rarely throw the CEL, and the idle stumbles sometimes but most times shoots up to around 3k, and can be adjusted down but then the idle stumbles and it stalls if u turn it down
Another thing is the timeing was 10 degrees out, turned it to were it should be and it pings like a bitch, turned it down some and it still pings
what gives??
Im thinking maybe the map sensor or something is causeing it to run lean is my guess.
