Topic: Super Coupe swap underway (Read 17441 times) previous topic - next topic
engine mounts
JeremyB, i need the brackets more then i need the mounts. i can get the mounts any ware i know, but i don't have the brackets and they are getting a bit difficult to find in your local junk yard.
1963 Lincoln Continental Cov. 455ci
1984 Thunderbird Elan 232ci 3.8L Super Coupe "in swap stage"
1998 Lincoln Mark VIII 4.6 280CI 4.6DOHC V8
                        :birdsmily:
If you were working on an 86+ I'd have you covered with my Type 8 mounts, but seeing as you have an 84, you need the "Mustang" type.
Quote from: Elantbird84;231645
ya know thats so  close i may just be fartin in the wind with my measurements. i whould like to get them from ya, i get payed on Wednesday, my i send you payment then?
Wednesday is Fine.I will need a zip code to get shipping cost and give you a total , if you are still interested in them,I will ship them out.
mounts
My zip is 98665.
                        :birdsmily:
The total will be $50.00.
If you can PM me your e-mail addy,I will send you a request for the money and I will ship it as soon as the money clears my wifes paypal account.
Joe
Which Rear end?
Ok, just thinking into the future while i wait for the engine mounts to arrive,
i currently have the stock 7.5 3:08 with track lock rear in the bird. With this new setup Super duty t-5 with the 3.8 SC engine, what rear end and gears do y'all think i should use?
i am figuring 8.8 most likely, but i want to try and keep the gears drivable, I would like to maintain some mpg if i can. so i don't really wanna go hi on gears. What do y'all think?:welder:
                        :birdsmily:
3.27's with a 7.5 rear. As long as you dont beat the  out of it, it will be fine. Also, 3.27's could be had from a hand full of junkyard cars.
Engine mounts
Ok, Big thanks to Chooglin, got the engine mounts. Just what i needed.
                        :birdsmily:
good to hear you got them ok...................now get out there and do some wrenching.
With a s/c 3.8 motivating things, you really don't need more than those 3.08 gears...especially considering our foxes are lighter than the mn12's...the 7.5 should actually be okay as long as it is a trac-lok unit.
-Don
Update to swap
Ok, sorry for the delay. i had to wait for a few to get more parts.did a compression check. 150 on 1,2,3,5  140 on 4,6 so she is good to go, that was wet and dry test. Replaced the Valve Cover gaskets today. Bolted up the engine mounts, and the headers.  :mullet:
Also have the front cover gasket kit. The front main seal is leekin. Going to do that tomorrow before install.
60.00 later for all the gaskets and bolts. i have it all attached now.
I did find one interesting thing about the setup. The engine mounts the Chooglin sent me have a alignment dowel on both mounts. My 84 cross member does not have a hole for the dowel on the driver side. Small difference from 83 to 84 i guess. Small trip to the grinder will take care of that.
P.S The 7.5 LS i have in there is a auburn unit. I am not going to go out and put slicks on or any thing. But i am going to go in and have it rebuilt. the gears are getting kinda noisy. That is why i am wondering if its worth it becouse of the money involved. is it just a better coarse to go and get a 8.8?
                        :birdsmily:
Engine in pics
                        :birdsmily:
cool....  Get'r done....  LOL..
With all the hassle I would have just gone 5.0L, but I like seeing people swap in something different...
Quick what flywheel is bolted to that motor??
Flywheel
its a neutral balance aluminum. i don't remember the brand at the moment.
                        :birdsmily:
