Topic: ? for the guys with AFPR experience... ***SOLVED*** (Read 2585 times) previous topic - next topic
Time for an update.  I installed a new Kirban AFPR today.  I was excited to find out this one actually adjusted the fuel pressure lol..  And then I was utterly let down when I fould out that I could not adjust the fuel pressure over 38psi.  I haven't looked at the pump yet -- I'm assuming the problem is here.  Is it possible that a hose is cracked or something?  I guess the only way to find out for sure is to drop the tank (something I'm not looking forward to).  Anything I should know about dropping the tank?  I helped my brother on his Cougar but that was probably 5 years ago.  Also, I was wondering where everyone got their Walbro pumps?  Just looking for a reliable source.  Thanks in advance for your replies!
Friendly BUMP
Tom posted a direct website no too long ago....Mine came in a holley box.  Walbro makes Holley pumps.  Have you tried pinching the return line?
If you pinch it like you would a garden hose to stop flow, you should see a spike in pressure.....
**EDIT** Here's the link:  http://www.autoperformanceengineering.com/
Still haven't gotten around to pinching the return line -- if the pressure doesn't spike, what problem would that point to?
Also, the link posted has 255lph kits and "High Pressure" 255lph kits.  Which one is best for my application?  Thanks a lot!
Pulled the pump the other day.  No real setbacks other than rusty bolts!  I pulled out the old pump which had a big WALBRO stamp on it...  and it rattled.  Something was definitely loose inside.  So I installed by BBK 255lph pump which had a big WALBRO stamp on it and voila!  Back into the boost!  Hey, I like my car again.  Feels like the first time...
...Feels like the very first time.
