Topic: How much you think it'd cost to fix this?!? (Read 4547 times) previous topic - next topic
There's nothing really structural behind the damage area other then the lower vertical brace inside the trunk well.
the entire panel itself is the structural part of the car, tying the roof to the frame so to speak (making it a short story)
Is that the only pic you got  from him?
I would check the cross-brace behind the back seat and the trunk wells real good. if you really wanted to measure to check the frame, I have the specs on the frame rails and measuring points. but you would need to jack it up to get under it to measure
also check the outer inside wheel well for damage. if it's damaged, another panel won't line up without repairing it
also look down the other side of the car with a light, but not in bright outdoor light. it will be easier to see ripples or waves that might have occurred from the accident. Dusk would be the best time to check for dents and ripples. But I don't think there is any frame damage by looking at that pic. but you never know until you see the entire car up close
this is whats behind the quarter panel
there's a little support in the front. but its in the inside of the car
here's the brace inside the trunk well
I think shop rate is $75 hr.
good tips, thanks!  This is really tough.  Could be a great car but I'm getting $3000+ quotes!  I could take the to San diego city college auto body or learn myself somehow.  I guess either way it will atleast be WAY better and ok to drive to shows and meets...  Then i can have it redone all-out later on.  I'd really like to learn this stuff just don't know if I could do it where I am...  Guess maybe the auto shop on the local marine base where my buddy works...?
1988 Thunderbird Turbo Coupe
I would get it, pound it out as much as you can, and just drive it for now
u can get at the panel if u remove the back seat and sail panels, and u can pound the back part from inside the trunk.
i cant see spending 3k on a car your gonna pay much less then half of that on the car. 3k on one area is insane.
yeah, but when you figure it'd cost that much to fix the current car anyway, I'd rather start with one that is dry and nice on the bottom.  I'll look into the school auto body shop too...
well for now it shouldnt be bad to just do that.
Its all how much work you wanna do!
Trust me I know the feeling, I would love to get another and replace my car, its so rotted, and filled with fiberglass patches!
I could never get a replacement for mine.
Although I wouldn't mind finding it a friend. :D
Yes, I already have my next project planned
Lol!!  Nice.  It's hard for me too...  First car I bought. :(
Does anyone know a good source of tutorials on a job like this?
Mabe,
what's it worth to you?
That brace behind the drs 1/4 panel is just for the spare tire to mount to from the way it looks.
The pass side has no bracing like that at all,so why would it be structural on one side and not the other????
Also there would be no reason to install a structural brace in an are such as behind the rear tire,no stress is projected there that needs bracing.
If you don't need your spare just cut it out.
That explains why there nothing in the pass. side. I always had a full size spare
I didn't even think of that. I knew it wasn't attached to the panel for support.
how much is what worth to me??  The car or the tutorials??
LOL-
Check out the main home page of the link I sent you
oops, oh yeah, I should have known that one!!
I had about the same damage(same side) to mine when the lady at the bank hit me about 1 1/2 years ago.
new rear quarter skin, tail light and whole car painted --$2600.00--
after pic.......
http://i216.photobucket.com/albums/cc154/flipnbird/DSCF0185-1.jpg
