Topic: FS: Cobra IRS assembly (Read 692 times) previous topic - next topic
Guys, this was meant to go into my 90 Mustang but it never happened.  It is out of a 2001 Cobra which has the 31 spline axle shafts. Now I have all the Maximum Motorsports poly urethane bushings for it, the control arm bushings upper and lower and the subframe bushings as well. I have the stock IRS springs to go with it along with the Bilstein shocks. It has 4.10 gears in it and I also have the 03/04 pinion strut brace for it. The Cobra brakes are still on it. The rotors need to be cleaned up but that is about it. I'm asking $1500 obo. It is located in Binghamton NY. I will post pictures of it tomorrow. Email: srvanddt at gmail.com
Thanks, James
Bump!
Still have this:
Ttt.......
Bump!!
This would be a cool item to have in a Bird or a Cougar! It is basically a bolt in job.
James
its to far for me would you part it out i need the hubs
Quote from: pegasus;249258
I'm thinking that is the route I may go but I would like to get rid of the whole thing first.
James
IRS IS SOLD!
