Topic: 3 Days!!! (Read 3505 times) previous topic - next topic
3 Days!!!
Here we are....down to the wire... who's ready?
I admit, I'm not...but, I do great under pressure! lol
Car needs a bath and detailed inside. Still need to pack. Still have to get all the Auction stuff together...... this should be a fun few days!
:cougarsmily:~Karen~
3 Days!!!
Whew, We dodged a bullet with a little part here and another part there...but in the end our Cat will be ready. :poke: :grinno:
3 Days!!!
I have to vacuum, and detail my cat yet too, and figure out a way of getting a body kit for a cougar in my trunk.....
just gotta pull the plugs and clean em, then a quick oil change and I'm good to go...
3 Days!!!
Quote from: EricCoolCats;226372
I'm not ready either...
You aren't supposed to use your outside voice! lol :rollin:
3 Days!!!
My Car's still on jack stands in the process of swapping the clutch, it doesn't help that I have to work overtime too this week
3 Days!!!
well I just finished up the exhaust on mine (sunday) and I am not liking it.so I will be heading out to the garage tonight, to see what I can do about it. other than that,all I need to do is give it a bath and I will be ready..............looking forward to meeting you all and checking out all these shagy rides you have.
3 Days!!!
Hey, what's happening in 3 days?
3 Days!!!
Quote from: daminc;226482
Santa Clause is coming :D
3 Days!!!
I'm getting close.  finishing up odds and ends.  I got to drive my car again on its first long trip on the new turbo/header/head/intake last night.  I'm still working on getting it running better and get all the exhaust work right.  I still need to get the a/c working and will be needing to keep it under 5000 rpm cause it leans out REALLY bad above 5000 rpm:mad: Its hard though cause it pulls so hard, and its only at half the boost I was running before:evilgrin:
3 Days!!!
k Cougar is all vacuumed, and I just got done doing the body work on the dented fender and my custom hood, and blasted them with paint tonight...  turned out good enough for CJ I think... especially since I am running out of time... after CJ I will redo the fender properly.. note the lack of the pinstripe as well, that took 4 hours just to remove the driverside of that ... cant wait to wake up and start on the passenger side....  YIPPEEE! not...
3 Days!!!
My Cougar (the '87 this year) will be the piest any of you have ever seen it looking. My June was just too full, and I had been deferring a lot of cleaning work that she has been needing.I barely got the driver's side door window glued back into its clips. I just got this done yesterday - Now I'm not supposed to try to roll the window down for 48 hours...like 36 hours to go!
I'll be hitting the road some time tomorrow. I guess I'll try to make it look presentable when I get there...
3 Days!!!
Nice job RJ!
3 Days!!!
I've got plenty of time I think.
Maybe?
3 Days!!!
I've got one tranny line leak to fix, do a once over twice :hick: and bolt the hood on :D  Then CLEAN.  Its filthy.
