Topic: How possible? Pics of block and trans....3/18/09 (Read 18467 times) previous topic - next topic
Reply #60
Quote from: massCougarxr7;262806
Actually when i first started this thread, and you pointed me in 460 fords direction, i instantly joined up, ive just been doing a lot of background, and build up reasearch....... thanks alot!!!!
 And hey ive been meaning to ask you..... are your 460s stock??? what kid of horse are they puttin out??? i know the bb is only pushin 240 in its stock form, but i was going to put rollers, cam, intake carb, and gears on it, what do you think????
Yes, both a pretty stock. Only a performer intake and 600 carb and MSD box. My guess is they put out about 290 hp at the flywheel.
Cam really wakes them up to a point....then a bump to 9.5-10;00 to 1 compression helps. The exhaust side of the heads are the big restriction.
I have been thinking of buying a set of those Pro Comp heads. For the price ( $ 1,100) they look to get me to about 400 hp and a cam change.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Reply #61
the tc looks like it hooks pretty good, what are your e/t's? The more i think about the swap the more i think about just slowly building it up piece by piece, and then dropping it in. And those heads do look good, the way i see it if im paying around 1,000 buks a head, i might as well throw another couple hundred at it and get even better heads.
[/IMG]
Just enjoyin the ride!!!!
Reply #62
I'd almost just stick with cast heads just figure out which are the best on a budget and get that combo working for a while. Thats just my inner penny pincher at work though.
Reply #63
yeah but if i just keep it on a stand and gather all the parts, build it to run strong, and swap it in.....
[/IMG]
Reply #64
Quote from: massCougarxr7;264130
The TC runs a 1.83 60 ft. and 8.60's.....that old engine is so worn out it just runs out of power on the top end. it hooks well with those 275-55-16 M&H Drag Radials. Torque convertor is a TCI sat. Night special. Trans is C-6. Engine shifts at 4400.
I am currently batting an idea around of buying a 521 shortblock from coast high performance and puttin those Pro Comp heads on it for a 9.0 to 1 compression ratio. Then a mild cam and a 750 carb. Then top it off with a turbo and 8 lbs of boost. By my guestimate it should get around 550-600 flywheel horse on 8 lbs of boost. All I need is 400 hp on the motor and add 8 lbs of boost to get 600 hp.
This way the engine should last for years.:D
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #65
You'll HAVE to make a build page while you do it.
Reply #66
Quote from: 86XR7project;264244
Good idea. I wasn't on this site the last time I built a car. I would love to keep the TC looking stock on the outside and have the blow thru setup under that stock hood. ( I measured...it will fit.:D )
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #67
yeah that would be cool, so you run 8.60 with a 290hp motor?????? was that a typo, or what am i missing?????
So whats the initial launch like????? I feel that torque is more important than hp.. but thats my own opinion....
[/IMG]
Reply #68
I would guess thats 1/8th mile, not quarter mile.
Reply #69
X 2...
I would bet that the stock rods could handle quite a bit. Unless you have like 90,000hp, I would think that torque would be a better way to rate a mostly stock internal peices.
Reply #70
Oh, ok....... i feel dumb now....... like i said before the stock rods are supposedly only good for around 350hp, not bad, but the stock crank can handle like 800-900hp, thats one strong S.O.B.!!!!!! At first i wanted to just dump the stock block in, and enjoy the power, but the H.O. conversion is shooting me only 20 to 30 hp less, than the stock bb.
[/IMG]
Reply #71
Think about the torque man! How many people can say they have a BB 87-88 Cougar XR7? You could call it a Cougar Eliminator Remix.
Reply #72
Quote from: 86XR7project;264360
You are right...1/8th mile.  I think 8.60s is equivalent to 13.60's in the 1/4. Remember, both of our Birds are low compression, small cam smog engines that shift way early around 4500. (they have stock rods)
The stock factory "football" rods with arp rod bolts are pretty strong. They came in 80's-90's 460 trucks. Ford also sells them thru FRRP. The stock crank is good to about 700 hp...easy.
The only advantage of the 460 over a stroker 351W is cheap, easy to find used parts and instant torque. The bad side of putting a BB in a Fox is the extra weight and lack of overdrive transmissions available cheap. When I built our Gray 460 T-Bird, there was no such thing as a stroker 351w available cheap. I want to put a 408W in that 83 Gray Bird so we can drive it on the freeway, but my wife says no, she loves that 460 BB.....lol:D
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #73
Quote from: 83-88T-Bird Guy;264464
That'll be close...
My Bird has run 13.11 on a 8.42 1/8 mile, but it always seems to run a couple tenths quicker in the second half of a 1/4 mi run than what the calculators predict... I need more converter to get it out of the hole quicker, best all motor 60ft has been 1.900... No it couldn't have run a 1.899, would have looked better on paper...
