Topic: Door channel run seal replacement FOUND!!!!!! (Read 809 times) previous topic - next topic
I was driving in town last week and I saw a mark 7 and I thought that the car has a lot of the same looking parts as my t-bird. So I went to the junk yard looking at the last bird in the yard and the seals were shot, then I looked at the mark 7 and they looked similar. I removed both and I found out that both are the same size, I found a very nice mark with seals that were soft and in prefect shape. I also needed the inside belt molding and it's about 1/4 in longer but they can be cut if needed also perfect shape. Their seem to be more of these available so this is a very good thing.
[COLOR="Red"]I am not sure if you guys knew this but for someone like me with seals that were not useable this was heaven sent, I couldn't be more happy. I hope this helps someone that was in my situation.[/COLOR]
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Did everyone already know this or did they just rot on my car
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
