Topic: 1986 T-bird restoration in progress.... Second restoration!!!!"Picture update" (Read 34233 times) previous topic - next topic
It is very easy to hook up, the only two connections are the pos/neg for the compressor turn key 12v and the horn valve you can put on a switch or hook to the pre-existing horn wire (like I have) The horn I have in the Bird sounds like a boat horn.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Well finally got some paint on the front end next weekend painting the rear shell, trunk and bumper. The parts came out wicked flat better then I thought I know py place to paint but it was prepared well so the nibs were minimal but wet sanding anyway enjoy.My wife is going to kill me for painting the washer
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I'd paint the whole freaking garage if I could get results like that! very nice! Do you paint cars for a living?
use to, but now I only do it as side work and when I need to paint something I F up. lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Really like that color red. Dude, train horn! Bad a$$!!!!!
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
The red is a ford red FL paint code toreador red, same color that comes on the excursions and other ford trucks
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
looking very good.any idea when you think it will be complete?
that color does look god btw.
that color does look good btw.
I would like to finish it by the end of the year, but you never know what might happen crossing my fingers.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Looks great!!  When you finish I'll run my '88 down to you..I live in Vero....
Here are some more pictures can't wait to finish it
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
more
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
My wife is already teasing me that she will be driving it to work YEAH RIGHT!!!!!!!!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
what size hood is that? nice work on the painting.
