Topic: driveshaft loop (Read 4194 times) previous topic - next topic
driveshaft loop
i run a driveshaft loop on my car but its homemade fron 3 inch flat steel rolled and welded to the frame rails with 3 inch band and depending on your rules and type of racing is where you decide to put the loop its good to have one on the front of the driveshaft but i have a second one about halfway down the driveshaft as well incase the rear u joint fails..
