Topic: Failed emmissions test... BAD (Read 2981 times) previous topic - next topic
The knock sensor has nothing to do with emissions, just retards timing if it detects detonation...
To test the knock sensor when doing a KOER test, you must goose the throttle to near WOT(and tap the brake)just after you get the engine cyl code(20)...
Ok, got it. Hey when I replaced the plugs I used Motorcraft Platnium, whas this a good idea or not? Im starting to have my doubts. After about 2 minutes of idling, the engine gets a lil jittery to the point you can hear some slight misfiring in the exhaust at idle and you can feel vibration. But if you didn't really pay attention you would not notice it.
I know it is said that our engines do not like platnium plugs but I had bosch platnium in my 88 for 2 years with no problems. They looked really good when I pulled them. I did change to the NGK T5 to see how it runs with them. So far so good.
Well Im going to replace the plugs with non platnium style. I will buy better wires and im seriously considering other alternatives as well. Dont smack me but I used Valucraft plug wires from autozone.. May have been a bad choice. I just notice that in the lower RPM's the car sounds like it sputtering, almost a misfire, (barely noticable).
