Topic: No locking your keys in the car (Read 2797 times) previous topic - next topic
I believe i see one flaw,,,,
the key reminder switch is a "one wire" switch.  I do not think there is a ground wire meaning the chassis of the switch provides the ground.  If thats the case, s this idea.  there would be no way to wire out the door switch if this is the case.
anyone know if the key reminder switch is a one or two wire device?
Quote from: jcassity;223507
One...
I know my '91 Maxima had it and it worked great, but it also had keypads on both front doors so I never really had to use it.
Quote from: TurboCoupe50;223510
One...
I figured thats what is meant when the symbol for the ground is flush with the symbol for the switch in the diagram.  Thats why i asked, plus since im not in the column often, i recall a single back wire near the key tumbler.
i almost said,, aww ,, then thishiznit me.
This circuit should auto unlock the doors just fine.
locate the wire coming off the key reminder in the column and cut it.
extend both ends up to the new door switch and done.
sounds like a 5 dollar upgrade to me.
the reason for the added door switch is because the existing one passes power through it, the new door switch will supply a ground path.
