Topic: Arching Rotor / Distributor Cap (Read 5459 times) previous topic - next topic
Quote from: dw85745;222742
That was one of the questions I posed -- if polishing the terminal would help.  Original thought was the smoother the terminal less change for arc to fragment and possible create extra gases.
David
Smooth, rounded surfaces will increase the voltage necessary to jump the gap...
A arc will more readily jump from a irregular/sharp/pointed object...
TurboCoupe50
Another interesting point.  Maybe that's why I had less issues with the multi-point rotor.  Even though per Standard QA was designed for RFI, maybe a side benefit was less buildup because of point.  Another issue may have been the gap.  Unknown whether gap on wire < gap of blade type.
BTW corrected other "Arch" to Arc
