Topic: 5.0 running terrible (Read 2927 times) previous topic - next topic
you can re-calibrate your tps sensor using jcassity's thread, or doing a couple of searches. Run your codes, its free, easy to do, and will tell you more likely then not what your problem is so you don't have to guess.
okay, i just checked voltage on the tps using the way jcassity's thread says to do and it seems fine to me. its starting with the throttle closed at .935v and smoothly climbs up to 4.593v with the throttle wide open so idk what the problem is. im thinking theres something in the computer or some wiring messed up or something. i think im gonna go get a new radiator tomorrow so ill probably try to drive it in and have codes checked tomorow afternoon.
Good luck. And let us know.
