Topic: Dash Modification (Read 2604 times) previous topic - next topic
Dash Modification
A piller pods from 1994-2004 Mustang
http://www.coolcats.net/modifying/gauges.html
for 87- 88
the same will work but cool cats also says that these will work
coolcats-
Again, adding a 1994-up Mustang A-pillar bolt-on pod will work. For 1987-88 cars, Geno over at Lincoln Motorsport has engineered a double-pod Lincoln Mark VII A-pillar replacement panel that is a direct fit in your interior. You will have to get yourself a filler panel for over the driver's door, found easily at the boneyard from a 1983-86 Cougar or Thunderbird. And you will have to (carefully) drill one hole in the roof panel to mount the LMS panel. Fit and finish is reported to be good, and the grain perfectly matches your interior. You will need to paint the panel though. And triple pods are not available. Still, this is a very slick, custom way to mount 2" or 2-1/16" gauges in style and keep them in your line of sight, where they're needed most. Just think: a full digital dash with digital gauges stuck on your A-pillar...too cool.
