Topic: H.O DA1 speed density computer (Read 1401 times) previous topic - next topic
Quote from: Quietleaf;221878
The mystery deepens. The car was in the shop to fix the passenger window and because it's been running py. I asked about switching to an HO cam and computer, and they said that when I had the engine rebuilt they had put in a cam with more lift when they switched to 19# injectors (but the same computer). So now I don't know what I have...maybe 86 HO cam? I have no idea what cam choices are out there. They said the cam was matched to the injectors, and since they've been neighbors for 31 years I'm inclined to believe them. Now I'm kinda wondering what's in there.
What's your firing order?
I imagine it's the SO order since they said they didn't change the computer.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
just out of curriosity, what makes the DA1 computer better(this is the one that i have)?
It's for auto or 5 speed,and I was told that the program is slightly more aggressive.
Quote from: Quietleaf;221918
If you get a chance check it just for fun.
bumpy
I'll need one in a few months if you still have one, got other things to buy first
I'll set one aside for you for our trade.Got you covered.
Your the man Vin
Well,thanks a lot.I try to be.
