Topic: draining the cooling system (Read 2993 times) previous topic - next topic
Not to Hijack buuut...
I live in SA and our "water" is about 50% water 50% limestone.  I routinely use Vinegar to clean scale off things in the house.
The previous owner of the coug used tap and its got some calcium buildup.  I was planning on dumping about a half liter of vinegar into the system and letting it pump it around for a while.
Does anyone see a good reason not to do this?
-dz
Quote from: V8Demon;221972
Provided you don't have other issues.
QUOTE]
Such as?
My buddy I got the car from said they put a new rad in a few years ago when he was trying to get it on the road. I really dont think thats the case. Maybe a "used" new one, but not brand new.
I have a water pump on standby just in case. It was $32.00 :D
The again... even when the temp gauge was pegged. I had no signs of overheating. Maybe the ever trusty Ford gauge is incorrect? LOL
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
Ok, I'm trying to flush it right now. I drained the system from the radiator, and when the coolant stopped, I closed the fitting and started adding water. However, the water doesn't seem to be going anywhere and just sits in the coolant reservoir. I let the engine run for a while but it started to get real hot and there's no sign of any water going anywhere?
Add to radiator.
Add to radiator.
Ok, but I can't get the metal radiator cap off...how do I add it to the radiator?
Why?
You need to fix that issue ASAP.  How in the world is it stuck?
I say flush it with beer. I am flushing myself right now lol.
Why?
We're talking about the somewhat star-shaped metal cap on the top right corner of the radiator right?
I can turn it a little bit (enough to hear the pressure come off) but after about a 1/4 turn it just won't move anymore. Is there a special way to get it off, or should I apply more force?
Push down while turning...?  I hate to mention the obvious one?
Tried that, but will give it another shot later today. Never flushed the system before, so nothing is 'obvious' to me :o
Regarding the engine drain plug:
If you look just in front of the motor mounts from underneath the car, you'll spot them. The passenger side one is easily accesible while the driver side has a bit more stuff in the way (oil filter and oil pressure sending unit).
It's the one inside the blue circle, right?
Digging this up....Didn't see your last post.....
Actually here's what mine looks like.  The driver's side is similar.
