Topic: Parts for sale!! 88 turbo coupe, and misc parts. Tons of stuff!! (Read 2339 times) previous topic - next topic
K....Send the info....The MO will go out tomorrow.
If you got pics, post them please.
headlight switch
dimmer switch
window switch
seat harness and switches
If you want I can test the headlight switches, but the others will not work in my car.
and I PMed you
Box it all up.  The money order goes out tomorrow, 5/28/2008.
okie dokie
sounds good
Payment sent.  You have a PM
thank you much!
you wouldn't happen to have the cap that covers the whole(the one that screws down into the tube) on the fender for the power antenna would you??
Thanks
idk i can look
Do you still have the door armrest lights? Another dumb thing I need is the small circular lens cover for the glove box light which isd the same size as the ones on the rear portion of a full center console car. Send me a pic if you do to dans65bird@alltel.net Thanks Dan
yep still have those lights and i think the light cover is still on inside the center console is that the one you mean??
Dont have any good door gaskets do ya?
im sure the ones on the car are good, but the car is in kitzmiller MD
and im not hahaha
Im gonna have to bring back another load of stuff this year!
Quote from: daboss351;217930
1 full T/C brushed dash, and radio trim- [COLOR="Red"][SIZE="3"]55 shipped[/SIZE][/COLOR]
Pics of the dash and trim? Any missing tabs, cracked vents, etc?
Thanks
-Stephen
88 TC/5sp/Gillis being resurected
69 Stang/347/TKO/EFI
... lots of other wheeled toys ...
I think theres only one cracked tab thats it
ill look over it closer
