Topic: line lock? (Read 5423 times) previous topic - next topic
Re: line lock?
I'd get, but then again I am actually getting one.
Reason why is last year I wore out the rear brakes going to all the races I wnt to last year for my club championship. I would buy it just to save the brakes for doin burnouts. Plus you get a more consistant burn out.
Re: line lock?
well, my look on it was you could put more torque on the car with 4 brakes holding it than yo u could with 2 weather it was line locked in the front or the back. the only value i ever saw in them was the ability to bake the tires off the car without smoking the breaks. its always sounds cool to be able to say you have line lock.
~John~
Re: line lock?
I could care less about weather its "cool" to have a line lock. If it saves me from doing the rear drum brakes on my car every 8 months i'm happy.
Did I metion I hate doin brake jobs on drum brakes.
Re: line lock?
why could'nt a typcial gate valve be installed in line with the front brakes being operated by a cable.  all that wont cost no more than 10 to 20 bux plus a reclaimed choke cable from an old pick up or similar.
gate valve- like what you would consider to be an ON and OFF valve for an Air Compressor system in a shop. Like the ones used to cut off air supply.  Those things come in many shapes sizes, male/femal so you could mate it to a compression fitting on each side.
to operate it,, i think something along the lines of the old pickups with the choke cable up in the cab.
far more simple and eliminates so many parts.  Need a line lock then pull in the cable.,, undo line lock then push it back in.  could be a trigger device on a stick shift which is spring loaded so it opens back up after you let go of the trigger.
Re: line lock?
neet idea but would that be safe and reliable?
~John~
Re: line lock?
Quote from: shame302
did i miss something? :crazy:
same application as this.http://bcbroncos.com/store/product_info.php?cPath=22&products_id=49
its the same as a gate valve but is defered when presure is off.
still mounts in your cab
still have to reach and push something
Re: line lock?
hmmm, i know it says not to use it as an ebrake but......
~John~
