Topic: New Guy '86 TC (Read 4119 times) previous topic - next topic
New Guy '86 TC
Well, blackcardinal your right it is a sweet looking ride and again Welcome to :bowdown:  you & your new TC. :birdsmily: :cool:
New Guy '86 TC
Another 4eyed Turbo coupe YES! Glad to have you and Your bird is looking Good. For those brakes check into new front hoses.
New Guy '86 TC
Now thats something to work with.
Nice car
New Guy '86 TC
Nice Score!!!
Under 100k miles even. :headbang:
Welcome Aboard!
New Guy '86 TC
Thanks guys! I've got a full day ahead of me today with this car! Hopefully I can get it ready to drive on Monday. It idles really smooth! Once I check out the cooling system, I can't wait to get it out on the road.
New Guy '86 TC
That car's barely broken in, great score!  Can't wait to see it once you apply a little TLC.
__________________
Twin '85 TCs
White/ Grey 2-tone
New Guy '86 TC
Okay, so far it needs an ignition switch (already got it) and it appears the water pump is leaking out of the weep hole. I'm also going to change the timing belt (it hasn't been changed since '92). One problem I have is that the fan won't come on. I've jumped it to the battery and it works, so it's either the switch, or the water pump isn't pumping at all. Any suggestions? Is there a relay? I jumped what I THOUGHT was the switch (driver's side next to the fuel injectors), but nothing.
New Guy '86 TC
Speaking as the tired voice of experience, the electrical system is the weakest part of these cars.  And it's pretty weak as compared to other cars too.
Soooooo
My suggestion would be to rewired the fan(s) and forward lights (head & fog) with relay kits.  Replace the rear incandecents with LEDs.  There are some places that make generic kits or you can buy the components yourself.  Upgrade the alternator (and related, ie wiring and voltage regulator).
One wierd thing (to me anyway) about the engine fan is that it's tied to the a/c system, so make sure the a/c system is charged and functioning properly.
__________________
Twin '85 TCs
White/ Grey 2-tone
New Guy '86 TC
Rewiring...ugh...still, that's what's gonna have to happen eventually. At least I got the ignition switch replaced and got to drive it some today. It drives pretty good! I won't have it ready by monday, but I won't have much work to do to it. Thanks for the input!
New Guy '86 TC
I *think* that if you do it correctly, you'll just be adding power wires to the lights and and fan, wiring relays to the existing wires and power wires.
__________________
Twin '85 TCs
White/ Grey 2-tone
New Guy '86 TC
I never could get the factory rad fan to work right in mine. So  I went after market fans ,and controller. They work great.
New Guy '86 TC
Yeah, I'm pretty much there. I didn't have time to work on it today, but wiring it up myself with relays sounds like the way to go. Hey, the fan switch--it that the one on the driver's side? Directly under the upper intake?
New Guy '86 TC
Nice lookin' bird. Same color as Turbokitty and has a similar problem with the paint. Easy fix though. Just repaint it. :)
Ordinarily, I'd point out that the new guy has to bring chips, but seeing as you're from California....
How 'bout some granola. :D
New Guy '86 TC
Quote from: *MAYHEM*;217266
Soy is better for you. LOL
New Guy '86 TC
Gee, I was hoping to use my Starbuck's card...:D
