Topic: Putting the front suspension together (Read 4581 times) previous topic - next topic
Buying new inners and outers, and having the inners professionally installed ended up costing about the same as that kit.  That kit's probably easier.
__________________
Twin '85 TCs
White/ Grey 2-tone
I guess if my only two choices are either that kit or buying the SN95 parts I'll go with the kit since I would only be saving a few bucks doing the swap, and it would be more work.
t3skidoo, There were no visible cracks in the framerails, and I've had Kenny Brown subframe connectors welded in. I'm not sure what im doing for an anti-sway bar yet.
Regarding the MM kit, you might price check the parts before deciding.
Regarding the structure, chances are good the A/S bar mounts and frame rails are okay, but you want to verify, esp. if the car's been driven hard.  They get stressed from hard cornering.
__________________
Twin '85 TCs
White/ Grey 2-tone
