Topic: OEM Fuel Lines (Read 1985 times) previous topic - next topic
OEM Fuel Lines
Freeze the fitting, boil the line, and use bit of KY lube?
Having a tube of KY in the garage might look strange, but it works great for stuff like this!
OEM Fuel Lines
I'll go stick the fitting into the freezer right now.
About how long *ideally* should the line be boiled?
I had tried pastime to boil the line in water, and was at it for 15-20mins with no success.
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
OEM Fuel Lines
I think water boils somewhere around 212 degrees or so.100 degrees is nice bath water.
OEM Fuel Lines
Quote from: cougarXLS;213698
Doesn't water boil at 100 degrees C?
LOL Vinnie.... that's what my C was for.  You're right.... for those south of the border... I will have to remember to convert ;)
100 degrees Celsius = 212 degrees Fahrenheit
But more to my question... is that enough?  And for what duration?
OEM Fuel Lines
lol
You guys and your metric system
OEM Fuel Lines
Quote from: daminc;213712
lol You guys and your metric system
Yeah, I never did figure everything out... I am 6' 1", I drive at 60-70MPH on the freeway (I can't afford to get caught! Darn police...), it's currenty -2degrees C outside, and I weigh 68 kilograms.
My parents speak in imperial and I can barely speak metric. LOL
BUT!!! does anyone know how long I should be keeping a Nylon Fuel Repair Line (Type 12) submerged within the boiling water pot??
OEM Fuel Lines
if the water doesnt a heat gun should do the trick. heat
without a flame. just my 2cents[not metric] worth.
--irv toms
OEM Fuel Lines
A heat gun... as in a glue gun? soldering gun? something else?
Your patience is appreciated... I'm new at this :)
OEM Fuel Lines
This is a quote from a post I read on the Corral
Like said before put them in real hot water when I did mine I took a big pot put it on the stove got it hot not bolling but hot took some gloves and the line slid right on and then I threw it in the freezer and boom it was done took like five minutes and worked great for the last 15ooo miles but to each his own.
OEM Fuel Lines
So I guess it should work.
I will try again.
OEM Fuel Lines
Well, I finally managed to merge the nylon with the plastic connectors, and guess what!
I made one mistake to many, and the line wound up to short :evilgrin: !
So, I buy some more nylon line... I finally manage to get it!
Cougar X is going down the road again!!!
As this thread is in the Marketplace and not technical support, there is method in my madness.... or madness to my method...
I would still be curious if anyone has any OEM fuel lines.
Thanks everybody for your help!
Go :cougarsmily: Go!
