Topic: Cougar wont start (Read 3210 times) previous topic - next topic
Cougar wont start
Quote from: cougarXLS;213465
I believe it was jcassity that suggested to me that my alternator was producing an output of Direct Current (12V) and AC....
*AC --> Alternating Current
He also recommended replacing the battery and alternator as a matched set.
Quote from: jcassity;213480
id highly suggest replacing the battery and alternator as a matched set and retry.
Short of searching through various threads, I guess my memory served me well.  Thanks jcassity!
BlkCatXR7, if all the grounds are solid, I might consider the wisdom of replacing the battery and alternator simultaneously.
If the car will start when boosted, then it's obviously not your starter motor.
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Cougar wont start
...or replace the voltage regulator on the alternator and battery.
the voltage reg is pricey and falls short of the cost for a whole new alternator.
