Topic: 1987 Thunderbird Turbocoupe(in NJ) (Read 846 times) previous topic - next topic
http://southjersey.craigslist.org/car/632193290.html
1987 thunderbird turbo coupe 2.3 turbo,5spd $1k - $1000 (somerdale)
Reply to: sale-632193290@craigslist.org
Date: 2008-04-06, 10:42AM EDT
For sale 1987 turbo coupe 2.3 turbo, 5spd 182k. cheap running, driveable car or a nice project for someone, $1k as is. Car is located in south NJ
The car runs and drives, A/C works. I have been using it as a daily driver but it does need some work if you are looking for performance from it. The alt, battery and T-belt where replaced within the last 15k.
known issues with the car:
4th gear grinds unless you granny shift it, been like that since before I got it.
oil smoke on initial start up only, does not smoke otherwise.
E- brake doesn't work cables are missing
R/R axle bearing needs replacing, makes nosie while cornering.
