Topic: Gas Tank: Vented? Pressurized? Vacum? (Read 1261 times) previous topic - next topic
Still working on the old '85 30th Anniversary T-Bird.  I changed the tank recently (all new tank, pump, filter).  First time in 8 years the car had a full tank of gas run through without breaking the fuel system open somewhere (sat for 7 yrs... after engine repair ended up with routine filter changes... 3 per tank of gas!)  After getting low on gas, I stopped to fill up and the tank was eiter pressurized or had vacum applied.  I don't remember the car doing this before, and I thought the tank was supposed to be vented.  Does this happen to anyone else?  I live in TX, so I thought maybe it's pressure from the heat, but wouldn't it still vent through the charcoal tank up front? All the EGR stuff is still hooked up as original.  Do I have a problem?
I believe they vent through a hose that runs up to the carbon canister near the engine.  Its supposed to hold the vapors until the engine is running.
My cars frequently emit a "pshew" when i crack the gas-cap. If there is alot of pressure you might want to check your carbon canister and purge valve.
