Topic: swapped the hydrobooster out (Read 2804 times) previous topic - next topic
Quote from: Red_LX;214022
I have an SVO master cylinder on mine. Stock prop valve, 73mm front calipers. Admittedly, the pedal is a tad soft, but it hauls the car down pretty well, I've made several panic stops since the swap and I've had no problems with locking up the brakes.
FWIW, I've read that when using the SVO MC, the acorn nut needs to be turned out about 1.5 turns to stiffen up the pedal feel.  It's only what I read though.
Supposed to be a 0.010" clearance between the pushrod and MC.
1987 TC
