Topic: Possible "new" product? Testing the waters (Read 4940 times) previous topic - next topic
Optimal caster + camber adjustment without the harsh spherical bearing? Sounds good to me.
Quote from: Cougar5.0;207626
Yeah, for most street cars, the infinitely adjustable caster is just not needed.
i would be interested in a set or two. A set for the SVO for sure, and possibly a set for my TurboCoupe  :)
1985.5 SVO
Quote from: turbo83coupe;207630
Can't help you there ;)  These would be Tbird/Cougar specific.
I’m interested
I was going to buy the ones for a mustang but I rather give you the money.
So what you saying is these only go so-much caster and on the other ones it’s wasted. And as for the camber they will work the same.
Quote from: Innes;207643
Unless the car is tweaked, being able to dial in the caster to dead nuts isn't necessary for the street.  Most cars won't vary enough for it to even be an issue.  The camber adjustment will be the same.
would they work on my lincoln? I know u said bird and cougar specific, but the plates for the bird are said to right the lincoln which is why I am curious.
Yes, they would be the same.
awesome! And those would allow for a strut tower brace to be used as will it looks. Id def be in for a set once the car is on the road!
Quote from: Ether947;207617
They are still $200 ($270 for the bling).
Would these work with SN-95/Fox Stang Struts?
Doh. I keep thinkin' they're $300 for some reason.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Chuck, you know I am good for a set. Your stuff is all over my car.
Count me in on a set definitely !
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
count me in for shure!
~1988 thunderbird~
In hibernation, waiting for spring.
I'll take a set, for the XR-7
ill take a set for the vert.  and maybie one for the xr-7 later
OK, well I have some work to do to get the pricing and details sorted out.
I'll report back once I have a better idea.
