Poll
Interested in Seat Braces?
Total Members Voted: 23
Voting closed: March 13, 2008, 02:47:26 PM
Topic: Seat Braces (Read 6132 times) previous topic - next topic
Seat Braces
So if i got UPR subfame connectors welded in can i fit these on the car or not?
Seat Braces
Quote from: Carpimp1987;207956
No idea.
These are made to fit a 2" wide piece of tube that runs straight between the two subframes (no offsets).
Seat Braces
Wish i would of took a piucture of them on the lift today sorry but for $23 i had to ask. Do you happen to have a picture of these installed with any kind of subframe connetors?
Installation question
Would it be better to weld the brace to the floor or bolt it in?  May sound silly but I'm not a metallurgist.
It looks like the reinforcement plates for the seat mounts need to be massaged for the crossbrace to sit flat.
__________________
Twin '85 TCs
White/ Grey 2-tone
Seat Braces
I cut the inside lips off the seat supports on the car and I'm welding it to the floor and original supports. Bolting may be your easier option though.
Seat Braces
They are meant to be bolted in, but I suppose if you wanted you could weld them, but there really isn't a need to.
As far as the reinforcment plates go.  First, replace the studs w/ bolts (about 40mm long).  On the 12mm side, the nut plate in the floor is tall enough, but on the 8mm side, you will need a little bit of spacer between the nut plate and the crossbrace.
Seat Braces
Thanks!
__________________
Twin '85 TCs
White/ Grey 2-tone
Seat Braces
so i bought the crossbraces... yeah :)  soooooo, does anyone have these installed?  if so, can you post a pic of them installed.... i just want to make sure i put them in right :)
thanks
Seat Braces
here's a pic
Seat Braces
Reply #39
Hey, weight that before you weld it!
__________________
Twin '85 TCs
White/ Grey 2-tone
