Topic: Motor Mounts? (Read 2384 times) previous topic - next topic
Motor Mounts?
As most of us know the stock motor mounts for the 5.0's in 87 and 88 do not hold up well to a modified 302.  So I am looking to replace them with a performance mount.  I have called summit racing and they directed me to tdperformance where they only list rubber replacement biscuit type mounts.  Has anyone found a poly mount or solid mount that works?  If so where did you find it?
Thanks,
Doug
Blueprinted 306, Thumper ported Canfield 195's, TLSR Camshaft, custom motor mounts, Parker funnelweb, Pro Systems Carburetor, Tremec 3550 II, 4.30 gears, Moser Axles, Team Z custom suspension with upper relocation brackets and anti roll bar.  At the track I run M/T 26/10's on Weld Star rims.
Motor Mounts?
Thanks
