Topic: 87 Thunderchicken Running Rich HELP.. (Read 2107 times) previous topic - next topic
ok see this is where me being new come's in to play lol the o2's are on the manifolds i thought they were like GM on the cross over pipe thats why i said no but i will go out in the snow right now and check these things brb.As far as disconecting the TV cable if you mean kickdown cable yes it is gone cause i went with a after market B&M shifter.
First off let me start by saying WOW WOW WOW this site rocks.I followed what everyone said starting with vacume lines connected any that were not connected.Started the car still no go running rich and not idleing.So i tapped on the fuel reg and looked for the map sensor to check plug well i found it and what do i find????A vac line not connected to the map so i hook it up start the bird and she purrs again no smoke idle's on her own smooth as a "BABY'S BUTT".So thank you to everyone that help i'm hooked to this site now TY:burnout:
Quote from: R4WTHUND3R;204730
:D
Let's start at the beginning.  Read these:
http://www.coolcats.net/
http://www.coolcats.net/fox/1987.html
http://sbftech.com/index.php?PHPSESSID=73470ad851831c88b4fca17f456f0aa3&topic=119.0
Your motor SHOULD resemble this if EFI.....You most likely don't have the MAF though;)
if I would have read this I would of told ya after the first post...
Well,we really do rock.You're lucky you found this place.
