Topic: SN95 dash? (Read 4305 times) previous topic - next topic
SN95 dash?
I didn't want to take over anyone threads so I'm starting a new one...
Has anyone completed an SN95 dash swap yet?  I had a few questions.  Like, did the mustangs have autolamp that can be spliced into the thunderbirds system?  What airbox is used?  fox or SN?  Any other HVAC issues?  Pedal assembly?  Cruise control?  Did any SN cars have audio controls on the steering wheel?  I'll have more later... I SO want to do this!
1988 Thunderbird Turbo Coupe
SN95 dash?
hmm...  Even better??  How about an 05+ mustang dash?
SN95 dash?
i know you have to use a sn95 pedal assembly, sn95 steering column, and then you have to cut your firewall up for the shaft support bearing. then you have to find a way to adapt your steering shaft to bolt up to the fox steering rack.
like i said in the other thread. do a search about it. not many people, nor i, have enough experience with it.
1979 Ford Fairmont
[/B]
SN95 dash?
Does it look like your a-pillar trim will look ok next to the sn dash?
SN95 dash?
baxo has started this swap but hasn't finished it....
SN95 dash?
Ok, so I know that the s197 dash is too wide to even cut down and fit.  I just had another question about the SN dash for you, 32V:
How do you know how much to trim off the back?  I'd probably figure it out upon seeing it but I was just trying to get some more info before deciding if I'm going to do it.
Also, as an extra side note, I found one guy that modified/fabbed column brackets and used his fox column...  just so anyone else knows that it's at least an option.  I'm thinking about maybe doing that to keep my TC wheel (especially since I spent so much time adding my new wireless audio buttons!)
SN95 dash?
tpuppies was done on the top part of the dash "pad" to close the gap on each end next to the a-pillars. on the driver side the sn95 dash use a large metal pipe for the air duct. you will need to trim that too, to clear the inside of the body.
1979 Ford Fairmont
[/B]
SN95 dash?
I see, so, the firewall has a deeper curve on the SN cars?  I was thinking you'd just have to make a template of the fox dash, line it up so it meets up with the sn dash on the two ends/corners (by a-pillars) and cut off the extra.  So, the far two ends don't really get cut... ...kinda?  It's hard to explain what I'm thinking but does that make sense?
SN95 dash?
you would have big gaps on the sides of the dash, where it goes up against the door seal, if you were to just transfer the curve of the fox dash to the sn95 dash.
1979 Ford Fairmont
[/B]
SN95 dash?
Well, i guess that's what I'm trying to understand.  How do you know where and how much to cut?
SN95 dash?
install, measure, remove, trim, re-install, rinse, and repeat.
1979 Ford Fairmont
[/B]
SN95 dash?
LOL....  ok, I'll take it!  I'll just wait and I'm sure I'll figure it out when I get there....  I just can't hold back my curiosity...  :hick:
SN95 dash?
I don't know if you put your seat in yet, but do you think the SN dash will decrease knee clearance?  I sit pretty close to the wheel, to the point where my knee is very bent and sticking up (sort of).  just wondering if I might have a problem there...
SN95 dash?
i couldnt say. i dont have my seats mounted yet, and i dont know how long your legs are, or how much deeper(if any) the sn95 dash is.
1979 Ford Fairmont
[/B]
