Topic: 460 sound (Read 5914 times) previous topic - next topic
460 sound
Quote from: gunkel04;206354
This used to be my vehicle, I believe the problem is that either the paper in the speakers has dry-rotted and cracked (120 degree temps here in the desert), or the head unit is dirty (sand from the desert here). The system was a complete oem mach 460 setup, speakers, harness, amps, head unit, etc. The tweeters I mounted behind the dash speaker grills, not in the doors under the mirrors. The 10 disc changer was from the same year town car, I simply grafted the oem changer harness into the oem mach 460 system, not hacked as I used the engineering schematics from both vehicles (not the evtms). The system used to sound tremendous when I first installed it back in the 90's, as I said before, I suspect time and heat has taken it's toll. FYI, I have another new mach 460 system that came out of a mustang convertible of the same era, all speakers, amps, harnesses, head unit/cd player, etc. All sitting in boxes...
So it seems an easy approach would be to check through the speakers and headunit to see what needs replacing and just buy Mach 460 replacements off of ebay (they're pretty cheap) and see what that gets you.  That'll save you from re-wiring everything and will sound pretty darned good.
460 sound
I would agree, or after determining what the problem is, he could ask  me for replacements...although I believe he is currently concerned with bigger issues.
460 sound
Go buy a poineer CD deck at wal-mart 4900 or 5900 should be about $140-180 might even have them on sale.
460 sound
Quote from: gunkel04;206513
This car was totaled correct?
460 sound
That was what I thought, however I believe his last post indicated that he was going to fix it...
