Topic: Mid/low 13sec 5.0 project (new video and pics 7/11) (Read 249542 times) previous topic - next topic
Reply #135
Here's the type of converter I'm dealing on
http://cgi.ebay.com/ebaymotors/B-M-40438-Torque-Converter-Tork-Master-2400-Ford-AOD_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el1262QQcategoryZ63692QQihZ011QQitemZ320270491462QQtcZphoto
Reply #136
ahh im so glad I passed that deal on to you, I knew youd want it!
Reply #137
I just got an offer for $150 shipped on a Crower 15511 cam. Specs here:
http://store.summitracing.com/partdetail.asp?part=CRO-15511&autoview=sku
Hard to pass up a deal like that on a cam that's known to work really well on speed density.
Reply #138
Quote from: kingcars;226646
You're shooting yourself in the foot.
Reply #139
Quote from: CougarSE;226664
I've already been up and down this road several times.  As long as the cam choice is right (stock HO, Crower 15511, Comp XE264/270), SD is fine.  Feel free to donate some money and/or parts so I can swap to MAF.
Reply #140
Wow $355! thats expensive. If you need to convert to mass air let me know I have a mass air computer and meter for sell that is setup for 24# injectors. I haven't posted it yet but I'll let them go pretty cheap.
Reply #141
Quote from: kingcars;226671
Really try to go with MAF instead of SD. My combo runs soooooo much better on MAF than SD that it's not even funny. If you shop around you should be able to get everything you need for less than $150. Find an 89-93 5.0 Stang at the wreakers and just grab everything you need to convert to MAF. Go to the wreakrs or find some local Stang guys to get the stuff from. The stuff you see on ebay is way overpriced.
Reply #142
this guy has an A9L and mass-air harness(no injector harness) for $175
Matt
832 725-1722
1979 Ford Fairmont
[/B]
Reply #143
I'd love to go to MAF, but it's really pushing my budget at the moment.  I'm currently saving to pay off the aluminum heads and possibly jump on the deal with the Crower 15511.  But if I go MAF, I'd be tempted to get the comp XE258.
Reply #144
ill look around for you, i find some  good deals around here for stuff
just tell me what you want and ill see what I can do. You know I'll take care of you bro
Reply #145
I've got a lot to think about.  The deal I could get on the Crower cam is really really good, and it works well for SD.  But if I end up going MAF, I'd prefer the really low end power band of a cam like the XE258 that probably wouldn't run that great on SD, and then it would be a good idea to go for a 24lb injector setup, which is even MORE money.  So I don't know yet...I just need to stop changing my plans.
Reply #146
im gonna pm you
Reply #147
Ok well I've made some final decisions:
I will not be going MAF right now.  Don't have the budget room.  Either the stock cam or the Crower 15511 cam will work perfectly fine with SD.
Heads and intake will not be ported at this time, also due to budget room.
I will not be needing 24lb injectors at this time.
Ok, with that said, the final decision I need to make is:  Crower 15511 for $150 shipped or stock HO cam for free?
Crower - Really great power from 2,200-5,500.  Highly recommended by guys running speed density, and even Tmoss said it'd be a great cam to go with my setup.  It'll definitely bump up my rwhp some.  Keep in mind that if I go this route, I'll be using 1.6 roller rockers instead, due to possible clearance issues with stock (mustang) 5.0 pistons. (Feel free to chime in on this clearance issue as well.)
Stock - Low end power = fun.  And it's free.  No extra rwhp bump.
Discuss the cams!
EDIT:  On page 2 of my corral thread, there's some very good cam insight.  Refer to posts 49, 53-59.  http://forums.corral.net/forums/showthread.php?t=1036977&page=2
Reply #148
Alright....well at least the corral folks helped me out...
Anyways, just spent the afternoon cleaning, sanding, and painting the upper intake.  Here's how she looks now:
Lookin a lot better, but I have one more trick up my sleeve before I consider it finished ;) .
I'm also workin on a deal for some 1.7 roller rockers.  :)
Reply #149
If you go with the Crower cam be prepaired to have to adjust the idle a bit. As I have run a cam in a SD engine it will require a bit of idle adjustment before it will run right (ie no surging/cut off when stopping). You can raise the idle with either the screw under the TB or one of those air adjuster plates that fits between the IAC and the TB. I have one I don't need now since I went to MAF that I can let go for $5 if you want it.
Also I wouldn't put drag radials on yet (like you were talking about in the Corral thread). I wouldn't trust a 7.5 with them as it increases the likely hood that you will break the rear..........
