Topic: motor has a hard time starting (Read 1856 times) previous topic - next topic
oh, and btw tbirdsps, I believe TFI actually stands for THICK Film Ignition.  But whatever, thick, thin, I don't know what it means!
1988 Thunderbird Turbo Coupe
im going to try the tps then the tfi. the tps is cheaper so thats the one i will fix first lol
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
hellsing73
DOOD!! your killing me!
you dont need a code reader, like i said, you only need a paper clip.
If you wanna get fancy, get one of those buzzers or beepers from some old toy thats broken or a real 12 buzzer like whats in your car.
Use the buzzer in substitute for the test light and you will have an audible code reader.
So,, basic parts to pull codes......paper clip
fancy parts to pull codes, paper clip and test light or dc buzzer.
even more fancy would be a "code reader" which is a waste of money.
http://www.therangerstation.com
or my diy link has all that  and codes.
Like i said, you need to go through that 3.8L with a fine tooth comb.  stalling and such could be clogged injector screens or carbon buildup on the base of the CFI.  Shot gun it if you want though,, its up to you.
Booksix
removing the red boot off the starter solenoid removes the 12 power delivery from the ign sw to the relay or winding side of the starter "relay".  the ground of the coil or winding is obtained by the two screws holding it to the side of the engine bay.  Un hook it and use a on/off switch (ie-remote start sw) from bat pos to "S" terminal and you can crank the engine over if the switch is held on.  Good for doing compression testing by yourself or whatever.
its not the y 3.8l its the 5.0l
:birdsmily:
