Topic: Post your NA times... (Read 10207 times) previous topic - next topic
Re: Post your NA times...
Best time ever in the car.
60 ft.:    2.116
1/8 mile: 10.017 @ 68.75 mph
1/4 mile: 15.671 @ 89.98 mph
More info here
Quote from: TurboCoupe50
So hows it run with the blower????
Bleh! Best I've done so far is 13.00 @ 108 @ with 6 psi pullies...  :disappoin
I'm upgrading a few things this year - cam, intake stuff, water injection, suspension etc... I'm hoping to be able to up the boost a bit at the track and get well into the 12's...  :flip:
Best time in the bird was an 8.27, that was with a 60' time of close to 2.0 at 89 mph. Best 60' was a 1.90 and best mph was a 91 mph
Well when i first got the car I ran a consistant 17.2 best was a 17.0.at like 80mph
Then the rear blew and so came 373's and full exhaust then we went 16.2 at 86 mph not to sure on tha mph though.
Then came the swap with the other mods you see in my sig
15.2 at 93 with a lousy 2.4 60' with a sliipn trans. Oh, how I cant wait to see 14's
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Times of my cougar dont cout no more.
Hope april 24 to be at the track when it opens and put down the same or faster times with a T bird.
Good lookin' LSC Mercoug.
'tanks. Although it seems to be a mojor task to keep it that way. I've owned the car for about 4 months and it has oncurred about 20-30 new scratches on it just from being driven. NJ sucks >:(
Duckin' agents like we was trapped in da matrix!
14.9@95 with  a 3second 60'...:( after the suspension upgrade this winter ill see how i do.
Mine times on my 83 cougar LS
1/4 - 14.85
mph- 95
i put a 351W in it with a c4 tranny mild shift kit 3.73 gears 8.8 rear end.
engine has a mild cam it was for a truck at the time i got it and stock heads with the small valves pocket ported. performer manifold and a edelbrock carb that runs like . shorty headers. only 9 to 1 compression. street tires so for about 40 feet i was spinning down the track (doesnt help the time any)
