idle probs. January 14, 2008, 08:49:30 PM i went to start my 2.3 the other day and had some probs. The car starts fine, it just doesnt want to idle. it starts, ans spikes up to like 1500, but then when it goes to drop back down to normal 1000 RPM idle it doesn't, it just stalls. It will run if i put my foot on the pedal and bring it up to 2000RPM, but as soon as i let go it stalls. I took the VAM off to clean it, and i also cleaned some other intake parts. I put all the stuff back on, and reconnected any sensors, is their something i am missing??? Quote Selected
idle probs. Reply #1 – January 15, 2008, 01:58:46 AM humm,try and see if the eec helps you when you pull the codes. Quote Selected
idle probs. Reply #2 – January 15, 2008, 02:13:45 AM Check the TPS for base voltage and/or dead spots. Quote Selected
