Topic: need to know what temp sender i need (Read 3912 times) previous topic - next topic
here is some pics of the wires and temp sender
[/URL][/IMG]
[/URL][/IMG]
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
dose any one have a digil dash that the temp gage works if you do could you put a pic of the temp sender on the block on here so i can see if i am even right on the one i need?
:birdsmily:
Ill take a pic of mine tomorrow.
Tomorrow came early.
Are you sure that other slip on boot isnt for your oil presure sensor?
Anyway, the sensor you have there is typically for a needle guage.  My dash is full digital and the sender is a two wire.
Here is what i have...
do the plugs look right to you?
:birdsmily:
dose any one know a way to check to see if its good or bad?
:birdsmily:
i have an 88 with the norm cluster and it has the same sender as my new one with the digilt cluster but i see that it has to have a kind of pluge i dont have on my car so im trying to find out where it runs so i can get it to work. but i think i know what i need to do now. just have to go get the sender and the plug and wire them up and it should work.
:birdsmily:
Alright in your picture with the two wires, the one that comes through the motor pull bracket is not  one that connects to the sender. In my 87 5.0 the shorter one that comes from under the plemun is what connects to it.
Where does the wire going through the motor pull bracket connect to on the other end?
wow i toled that car like a year ago and im pulling all the stuff off of it and puting it on a other car i got for 300
:birdsmily:
oh okay. another thunderbird i hope. I was searching through looking to find out why my temp gauge is pegged adn the car is cold. Thought i might be able to help.
My advice is to take a lot of pictures so you have them when you reassemble in the next car and bag and tag bolts/parts. Just my advice, I was glad I did.
ok thanks my grandfather is going to help me do the swap and he retired from fords a long time ago and helped make the 429 and stuff and he has a full grage with the lift and all
:birdsmily:
