Topic: Need help/advice (Read 1149 times) previous topic - next topic
Need help/advice
Here's a quick parts rundown that are in question: Mustang k-member, flaming river manual steering shaft and equal length shorty headers.
The problem: the pinch bolt/nut and lock pin are rubbing the header.
Possible fixes: 1: make spacers to go between the motor mounts and k-member. I am assuming that the 3/8" plates between the k-member and frame dropped the motor the same amount and put the header too close to the steering shaft. 2: spacers between the motor mounts and block. Probably a bad idea. 3: see if there is any way to get some movement in the steering column and keep it there.
I am hoping that the third one works out. Anyone have any experience?
Thanks
Jim
