Topic: what will i run (Read 2575 times) previous topic - next topic
what will i run
i have a 88 bird with a c4 and trans brake full roller 302 e-cam 4:56 gears in the back
what will i run
uhmm, somewhere between 1 second and 1 minute.
your information is too vague. plus the motor doesnt matter you have to factor in weight, temp, tire slippage, and your R/T
what will i run
true
what will i run
Quote from: 87thunderbirdBlackJack;196289
 and your R/T
R/T has NOTHING to do with ET...
what will i run
What type of:
heads
intake
headers/exhaust
Traction-Lok or not?
what will i run
You might run the quarter in 1:15 or so depending on how quick you are.  Your car on the other hand should cover that distance much more quickly.
what will i run
Quote from: Chuck W;196339
LMAO
1:15 there’s some other misc factors like his age weight and how’s his shoes tied.
what will i run
Quote from: Innes;196373
LMAO
Like I said...it depends on how quick he is ;)
1:15 is actually kinda slow.  I ran it in 56 sec WAAYYY back when in the city track meet when I was in Jr High...and I finished 3rd :p
I just figured it was an arbitrary answer to an arbitrary question.
what will i run
first time i had it out with the old motor and tranny i ran a 17...
what will i run
Quote from: thunderjet302;196332
What type of:
heads
intake
headers/exhaust
stock heads with 3 angle valve job ported
vic jr intake with a 700 cfm holly
kooks headers posi
what will i run
Thats a big carb for such small heads,  what stall converter?
running at what elevation?, slicks or street tires?
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
what will i run
slicks and a 3800 not sure about the elevation if any1 has been there i plan on running at kil-kare in dayton ohio
what will i run
the motor i had was running 11s in a fox gt with 3.73 on slicks
what will i run
What are you shifting at?
Is the cam installed with any advance or retard?
Pistons? Compression ratio?
I'm curious as to why a 3800 stall on some stock ported heads with an E-cam?  I understand you need a higher advertised stall with numerically higher gears, but 3800?
What does this converter brake stall at?
