Topic: a/c line and lower brackets for a/c condensor (Read 1266 times) previous topic - next topic
I need the lower brackets for the a/c condensor.I have the uppers.I also need a GOOD a/c line with the dryer (for a 5.0 car).I've decided to re-install the a/c system on the Bird and sell off the a/c delete and the Stang polished steering pump bracket.Let me know what you have.
hey Vinnie, if I decide to get rid of my old non working A/C i'll be deleting it so if I go that route I'll be more than willing to sell or trade you the whole thing top to bottom etc.
EDIT btw, all it would need to be working is new O rings.  I'm almost positive that the only thing wrong with it.
Quote from: vinnietbird;195945
The only GOOD suction line you'll find will be from an auto parts supplier. Never install a used one.
Why would you say to never install a used one? I think many guys have done it with no problems. I probably have sold several myself. Is that asking for problems in the future?
1987 Turbo Coupe - Son's car
1934 Ford - My project car
I can check Autozone for the line/dryer,but I still ned brackets.Actually,I need a good compressor as well.
The job of an accumulator is to absorb moisture via a desiccant and filter the refrigerant. The desiccant can only absorb so much and cannot be regenerated. A used accumulator may have a full desiccant, unable to protect your system if moisture intrudes. The results can cause orifice tube icing and compressor failure.
A new hose is $90.00.I may get the new hose and get the rest here.
I'm good.I got the lower brackets out of a box in the garage.I didn't remember keeping them.All I need now is a good compressor.
Vinnie is the ac delete off yet?
i thought all you needed was a smog delete pulley, i didnt know you needed a ac delete pulley, thought you used a shorter belt?!??!
Actually you don't need any deletes.You could short belt it.
Not yet.I still have to get a compressor and a new line with the dryer,then,it'll be off.The FRPP delete kit has about 500 miles on it,the bracket is from a Stang that I polished.Very nice,and the belt can go with it.The belt is for an a/c and smog delete car.It's about 6 months old....if that.
If you are still looking for some AC parts, I am in the process of removing everything from my cougar.  The Compressor worked but was slowly leading the black oil, The only line that was not in good shape was the lower one that runs along the radiator support.  The spring lock fitting at the evaporator core was leaking, but I assume you are going to install new o-rings.  Make me an offer on the stuff, I have everyting out of the car except the evaporator core.
Let me know,
Doug
Blueprinted 306, Thumper ported Canfield 195's, TLSR Camshaft, custom motor mounts, Parker funnelweb, Pro Systems Carburetor, Tremec 3550 II, 4.30 gears, Moser Axles, Team Z custom suspension with upper relocation brackets and anti roll bar.  At the track I run M/T 26/10's on Weld Star rims.
Hang on to that stuff,I'll let you know in a few days.I appreciate the help.
ill trade you the ac compressor for the smog delete and the mustang bracket :D
