Topic: AOD Casting numbers (Read 6304 times) previous topic - next topic
AOD Casting numbers
guess what... after i had the new transmission in, everything hooked up, the driveshaft was last before filling it up... the yoke didn't go in all the way.  the splines weren't machined deep enough on the new tailshaft... so instead of taking it all back out and swapping that shaft, i got the driveshaft shortened, yoke stock and unaltered, will this cause any issues?  the yoke doesn't go in as much as an inch... how much risk do i have of it falling out when the rear articulates?
AOD Casting numbers
Your doin fine by shortening the shaft.Of course balance it.
1" isn't much,I think you need a little more.
AOD Casting numbers
ya know, ive been readin thru some of the stories in your recent posts(and theres alot of em to read), and i started to get this sorta deja-vu type feeling.......
so, i did a lil diggin around and i discovered that the transmission story in this thread sounds a helluva lot like this one.
and the description in your wanted thread for center markers, here, reminds me a whole lot of this guys pics i found.
would be pretty lame to start a second ID on here acting like a newb all over again, and tellin the same stories. who are you tryin to fool? i mean comeon, lets compare the profiles; same location, same vehicle, your AIM screen name is even autocat5oh. how stupid do ya think we are? :mad:
so, you wanna come clean ~AC? or is it Autocat? :beatyoass:
AOD Casting numbers
i came clean and kept it clean in PM's.  thanks for everyone's patience and understanding on this issue.  thanks for letting me make up for being the previous d!ck i was to a lot of people.  i WAS autocat, i am now today AC.  im here for advice, respect the people here b/c of out of all car enthusiasts (other than being ford) they share the same intrests and to be honest, a lof of you guys are well worth my respect and a case of beer.
thanks again for everyone letting this blow over.  autocat was a snobby pos kid that thought he knew everything in the world and was superiror.  me, AC, have a lot of respect for people who work on cars b/c now i know how hard it actually is (well not hard, but it takes some thinking) so i'll prolly ask for advice and pass on any when its needed.  have a good day guys n gals :)
AOD Casting numbers
Your welcome!
AOD Casting numbers
i just noticed that i was receiving bad reputation points, and they're in a question form.  who do i contact b/c if they have an issue i would gladly discuss it with them and clear it up.  im not trying to pick a fight, i just dont want people to continue to be mad at me.  i regret posting this but i have no idea who to contact.  PM if you want, but i feel very welcome here, and i have stopped myself many times from posting thinking it might be a post w post.  im trying to keep clean here, i dont want any trouble or cause any.
btw thank you thank you to kitzdnm and everyone else!
AOD Casting numbers
Ok, I brought this question over here because we were starting to hijack the other guy's thread.  If the speedo seems to be reading correctly at highway speeds, then the sensor's driven gear, and the trans drive gear are probably the same as before, that is good news because you do not have to calibrate the speedo now.  Now the question is, how long does it display speed after you come to a stop?  2-3 seconds, or more like 30?  2-3 would be completely normal, just call it an old ass processing system playing catch-up to what is actually happening.  If the car never had that concern before, then it is slightly possible that you have a new signal feeding into the speed sensor circuit.  Problem with that is that speed sensor produce an AC signal, and these old cars dont have many of those, if any, near that part of the harness on the car to short into that circuit.  Look at the wiring harness at the top of the trans bellhousing to see if part of it is pinched.
Matt :tg:
AOD Casting numbers
cool i'll check tomarrow, im ganna try to clean up the front tomarrow anyway.  unless i get sidetracked.  i got a multimeter etc so i'll check the harness, got nothing better to do anyway.
