Topic: Ever got refused an emissions test? (Read 1854 times) previous topic - next topic
I did today:mad: :mad:  something about being to loud
That sounds more like a safety issue to me....
have you ran it at the track yet?
1979 Ford Fairmont
[/B]
Why don't you just slap on a ler?
Quote from: xjeffs;195658
it has 2 on it.
I was at a race once that required lers.  One guy there had a sweet 66ish Corvette with sidepipes, which were too loud.  His solution was to use a coathanger to tie a tin can over each pipe exit.  That was enough to get him through tech.  I still remember him pulling a wheelie with those cans dragging on the ground.
Moral of the story, get yourself something temporary - steel wool, baffles, something stuck into the end of the pipe.  Stop half a block away from the inspection place and install whatever it is, get the tag, then get it out.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;195660
See that would be fine except we dont have a safety inspection.All there supposed to do is do sniff test and a quick visual check for cats not a thing to do with sound or loudness.It all comes down to the inspector didnt want to do her job.because my car has turndowns (law reads 12" or an arm lenth under the car is acceptable) to be able to test wich mines falls within.
Try a different station.  I can't believe they have this in Tennessee.  We don't even have this in San Antonio.
gads, a lazy paper pusher.  +1 on trying a different location.  if that isn't an option, how about getting some more exhaust pipe from an auto supply to get it closer?
__________________
Twin '85 TCs
White/ Grey 2-tone
Glad i'm in NY,
 no sniff test here.
Only to make sure there's cats on it. and in 4 more years my car won't even need them.
Is it the same everywhere else after 25 years?  (the cat part I mean)
What's an emission test? LOL.No saftey or emissions here in Oklahoma.
No worries here either. We don't have  in middle to souther IL. Around Chicago you have to get them sniffer tested.
slip them a 20 and they will forget about it
No emissions in Kansas lol. Run straights on it!! We have to have lers, that is it. Its called "noise pollution".
