Topic: Making an Explorer GT40 upper work with SD (Read 1882 times) previous topic - next topic
So I thought I'd post this up for you SD guys:D .  If you want (or NEED to in my case) to use the Explorer GT40 intake on your 5.0 but you have SD it can be done. The first thing you'll notice about it is that the vac fittings are different from the stock intake. If you have MA you have enough fittings and the one on the lower front that faces forward can be capped off. Now if you have SD that lower fitting is ideal for a vac source for the MAP sensor as it needs its own fitting for proper vac signal (ie you can't run something else off it or the MAP gets a "dirty" signal and the car idles funny). Now the problem with that is you need to run vac hose under your upper and it looks a bit "untidy". Since my car is basically a show car I like to keep everything neat but I still need that extra vac source. Here's what I did. First I removed and plugged that forward facing vac fitting. It cleans up the intake and makes it look "stock". Next I got the vac fitting from the rear of a stock HO upper. I then removed the bent rear fitting from the rear of the Explorer GT40 and drilled and tapped the intake to accept the stock HO fitting. The vac connectors stick out too far and you'll need to cut about 1&3/4" off of the fitting to make it work. Now you have a GT40 Explorer upper that has its vac fittings in the stock HO location so you don't have to re-route your vac lines:D
what is that? ford grey? WTF?!?!?!?! you strayed away from that ugly ass blue!
hoo rah!
Quote from: 87thunderbirdBlackJack;195555
hoo rah!
Nope the Ford gray is what color it was when I bought it. Soon it will be getting a nice coat of FORD blue :D
ever try DARK ford blue?
light colors turn me away. get too dirty too quick
Quote from: 87thunderbirdBlackJack;195559
The dark Ford blue is too dark to me. Plus it wouldn't match the block and heads. The dirt is a non issue as I clean the engine and bay at least once a week :D
I actually love that light blue a lot. :flip:
Jeez thunderjet you and your eat-off-it engine bay!!! Grrr so jealous...actually to be honest mine would look a whole lot better with a can of degreaser and a hose. Maybe I'll get around to it. :hick:. That and a new radiator, for some reason all the fins on mine are either brown-red or green from corrosion and literally crumbling apart and getting blown all over everything like the accesory brackets, like confetti....but bad. :hick:
Hey, doesn't anyone remember my bright ford blue engine  that you can eat off of? Nobody ever references my car or engine...wait till you see my paint job in the spring, Nobody will forget my car then!!!
Oh, yeah..Hey thunderjet, how would you like a polished explorer upper/ford blue lower in which both have been ported out?
~1988 thunderbird~
In hibernation, waiting for spring.
in half the time it would have taken me to do all that, i could have rerouted my vacuum lines.
1979 Ford Fairmont
[/B]
Quote from: 87tbirdmanjwg;195652
Got a link to pics!!! Let's see the goods!!!! And yeah samsies when you get the paintjob. (nyuk nyuk...samsies..nyuk nyuk man superbad was awesome...)
I would but I think the one I have will work. I don't think the engine flows enough air to warrent a ported GT40 ;)
Quote from: 32VFoxBird;195656
I know I could have taken the easy way out but I'm trying to make it look stockish and less messy;)
meh, buy a real polished cobra intake and be done with it... :D
My Explorer intake.
Why not?  I would think you'll see some benefit.  Oh yeah, You need that converter I've been trying to sell too!
Quote from: V8Demon;195720
The heads flow 200cfm so I don't know how much increased airflow would help when the unported Explorer GT40 flows enough to support the heads. I wonder how much power the stock HO intake I used last summer was keeping the engine from making............. I decided to wait till the car comes out in the spring to install the GT40 because I want to drive it hard back to back with the stock HO and then GT40 intake to see how much of a difference the intake swap makes.
I know I need a converter but I'm trying to finish the intake and exhaust first;)
Quote from: 1WLD BRD;195717
Explorer flows the same and I saved $200 :banana:
