Topic: Opinion: Shift kit or 3.73s (Read 5082 times) previous topic - next topic
Well if you're going to be driving the car regularly (like a DD, like my car) then I'd say go with some 3.27s.  I just put mine in today and the difference in HUGE.  Turning 2,000rpm at highway speed in OD is as high as I'd want to go for a DD.  I'm also planning to get a shift kit in a couple of weeks (along with a new speedo gear of course).  Should be a great combo of mods.
Quote from: V8Demon;201294
D  on your shifter is 1st, 2nd & 3rd without O/D (otherwise known as 4th).  The mod Tom mentions deletes that option and the AOD will act as if in the D with the O around it position....
Paul, I'm not sure what you are saying...
Anyway the D position now only gives a 1st to 2nd shift and never any higher... O/D operates with the normal 1-2-3-4(O/D) pattern, only way to prevent the O/D shift is keep it on the floor... Works fine for drag racing, and with 3.73s I'm yet to find a mountain it won't scoot up in O/D...
With O/D 3.73s are fine on the highway... IF I ever swap gears, it will be for 4.10s... That's what's in my '93 Lightning...
D normally locks the overdrive gear out completely....I mistook what you said about the mod.  Word jumble in my head.
Quote from: TurboCoupe50;201357
Yep. I turn maybe 2300 rpms at 60 mph on the highway with 3.73 gears. Plus I still get about 24 mpg :D
After rereading the post it is clear now. Thanks.
The 3.73's would probably be great if the car would hook. The small 14" tires spin quite a bit. Good fun factor though!
 The shift kit would most likely be the best mod for the buck and time spent.
I'd vote for the stall before the gear.
  A shift kit with the right stall would be a great starting point. :burnout:
Quote from: t.birdsc;201511
Believe me I know........
The car is an XR7, 15" wheels...:D
I don't remember mentioning a stall, since this isn't the right oppurtunity for me to get one I wasn't worrying about it.
I'm going to be grabbing a shift kit first, seeing as I found one BNIB for $10.
Quote from: 88XR7;202748
That's a good find for $10. :)
A stall might a better choice before gears imho but I can't speak from experience. At least...............not yet...........:evilgrin:
Those 15" should give you a better tire than the 14" which are presently stuck on mine.
Good luck :D
 Mike
Definitely do gears before a convertor or else you will end up hating your expensive new convertor...too much time spent stalling the convertor with 2.73's will cause some excessive heat in the tranny...if you had 3.73's or better it would be a non-issue.  Shift kit is a good basic start...the 3.73's are definitely the bigger bang for the buck.
