Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1530070 times) previous topic - next topic
Reply #630
Dumb question. How are you removing the paint?
Reply #631
40 grit disk on a grinder @ about 1000 RPM. It won't heat the metal up and distort at that speed. Pretty much the easiest and cheapest way to remove the paint.
Are you from the autobody forum? Your name sounds familiar.
Reply #632
I don't know about easy, but aircraft stripper would be.
Then you can see whats tuffer the new floor or the cat.
I'm an A$$, I know!!.
Reply #633
Quote from: daminc;245790
Yes, I am. I am using that site and this thread to try to learn enough to complete my own restoration. (And this thread for inspiration! - Thanks for that!)
Reply #634
LOL
OK, I'm just plain cheap. cost about $2 for disks and a total of mabe 2 hrs to strip the hood and coat it.
Here's the rest of it done.
Here's a little surprise I found on the hood.
So I got done with that and on to this.
Here I just wedged it on for a look to see if it was going to work.
It appears to be the same.
I'll bolt the trunk lid back on, and work on the corner and the trunk fix next. And probably the tank brackets, so I can paint the underneath.
Until next time..
Reply #635
Quote from: freddk13;245844
Glad I can help, You never did post pics of the car, did you?
Reply #636
Quote from: daminc;245786
Just shipping.
I'll put it together with screws, and cut it in half for shipping.
I'll make it so you can put it together full length when you get it.
This way, it there's a slight diff. in frame, you can adjust it to fit yours.
How does that sound?
sounds amazing
Id owe you big time!
Reply #637
Quote from: daboss351;245932
sounds amazing
PM sent
Reply #638
Did some fiddling with this back corner today
don't ask about the pic, I don't know what happened there. LOL
found a better one. I put the lid back on to do some aligning to that piece.
Also had to put the lights back on to make sure everything was right.
I'll bet you didn't even know I had lights. lol
So everything  looks Ok there, I'll weld it up when I do the tank supports. that's next.
I also did some sealing and cleaning up in the trunk. I also removed almost all the seam sealer in here
Here's pics of the inside of the quarter panel repairs.
And I found this floating around in my tool cabinet. I should make it into a keychain.
That's all for today.
Look at me go!  :D  LOL
until next time
Reply #639
It looks like the corner piece needs to come down just a tiny bit more,but,I've only got the pics to look at.It may be different in person.Still,nice work.
Reply #640
It may have moved a little before the pic was taken.
I had the trunk open and closed a bunch of times.
I'll do better next time.
Reply #641
No worries.You're rockin' right along.Awesome.
Reply #642
I want to know of the weight of this when its done.
Have you thought about puttin tracks on it yet?
Reply #643
I don't think it's going to be any different in weight, other then the SFCs which is about 60lbs total.
Tracks?
Reply #644
I think he meant Tank tracks, as in "It's built like a tank" ;)
I still say you shoulda installed T-Bird tail lights :D
